Deep sleep power consumption - has something been changed in the latest ESP_IDF release?
Re: Deep sleep power consumption - has something been changed in the latest ESP_IDF release?
I am looking at the 9mA mesurement but don't see the connected ESP32? only some kind of resistor? Missing some thing? What voltage are the (same?) batteries?
Similar setup with different multimeter:
Source https://github.com/pcbreflux/espressif/ ... leep_timer
LiFePo4 3.4V
LiFePo4 3.4V
- Wakeup 55mA
- tmp_10507-20170213_150849176190867.jpg (3.48 MiB) Viewed 22058 times
- Deep sleep 20uA
- tmp_10507-20170213_150918-1779826605.jpg (4.25 MiB) Viewed 22058 times
Blue NOA board is disconnected on the picture with 9uA measurement. ESP32 is just not fully visible on the photo, because it's a side view - ESP32 mounted on a small PCB with battery handlers and powered by 3.2v LiFePO4.
Some additions to the mesurements with the Fluke 17B+:
losses: Long leads, battery holder leads,
crocodile clips, breadbord + wires + pcb adapter
dmm accuracy at mA 1.5% +-3 Digit
uA Range ESP32 dont start
burden Voltage?
shunt ?
burden Voltage?
shunt ?
- Start with WiFi (MQTT Example)
- tmp_6366-20170213_150336-1172464652.jpg (3.46 MiB) Viewed 22049 times
I can confirm the 35uA current consumption in deep sleep mode in the latest ESP-IDF (that's the ESP32, flash chip, and pullup resistors current combined). This may be caused by a regression in RTC clock setup code, we're investigating.
When librtc going to be open sourced?ESP_igrr wrote:I can confirm the 35uA current consumption in deep sleep mode in the latest ESP-IDF (that's the ESP32, flash chip, and pullup resistors current combined). This may be caused by a regression in RTC clock setup code, we're investigating.
Turned out to be unrelated to RTC clocks.
You can add these two lines at the end of bootloader_random_disable function in components/bootloader_support/src/bootloader_random.c:
We'll have this change in master soon.
With this change, supply current is back to 5.5 uA in my test.
Edit: here's some more detailed info:
Current value is the total of all supply rails. Flash is powered from internal regulator.
/* Disable pull supply voltage to SAR ADC */
CLEAR_PERI_REG_MASK(RTC_CNTL_TEST_MUX_REG, RTC_CNTL_ENT_RTC);
SET_PERI_REG_BITS(RTC_CNTL_TEST_MUX_REG, RTC_CNTL_DTEST_RTC, 0, RTC_CNTL_DTEST_RTC_S);
RTC_PERIPH RTC_SLOW_MEM RTC_FAST_MEM Current, uA
On On On 6.3
Off On On 5.3
Off Off On 4.9
Off Off Off 4.5
New Setup with new esp-idf: looks fine
commit 13dfb5568dcc30aa43363c49f7a4505d04036424
Date: Fri Feb 24 22:23:06 2017 +0800
Module: ESP-WROOM-32
Adapter: only Reset with 10k Pullup and GPIO 0 Button, no other components assembled
LiFePo4: Soshine 18650 3.2V 1800mA
Teststeps:
Step1: Flash deep sleep Test firmware: (https://github.com/pcbreflux/espressif/ ... leep_timer), GPIO_DEEP_SLEEP_DURATION=1000
Step 2: USB to UART converter removed
Step 3: to start Fluke 15B+ is bridged/shorted (assumption: DMM shunt/voltage drop in uA range to high, Volt on Fluke 17B+ ~1.8V)
Step 4: when ESP32 enter deep sleep bridge is removed
Teststeps:
- DSC01033.JPG (4.42 MiB) Viewed 21875 times
Hey, better than before, right? 9.46uA -> 5.1uA? Nice.pcbreflux wrote:New Setup with new esp-idf: looks fine
I got the same problem with the current consumption in deep sleep. Can you make the Firmware available again (Link is not working)? Or should it work with the current status of firmware?
Best regards,
Matthias
Best regards,
Matthias
Users browsing this forum: Google [Bot] and 232 guests
