Welcome to use ESP31. Here is the ESP31_RTOS_SDK_API Reference.
Click to download.
Enjoy !
[Documentation Release] ESP31_RTOS_SDK_API Reference
Re: [Documentation Release] ESP32_RTOS_SDK_API Reference
hi guys
Docu update at Github, ESP32_RTOS_SDK V2.0.0
here comes the ESP32_RTOS_SDK_API Reference V2.0.0
-> PDF Docu
-> HTML sites
Enjoy!
rudi
-> PDF Docu
-> HTML sites
Enjoy!
rudi
Hello.
Is there any API document that describes how the Bluetooth onboard can be used? I searched the few documents that I came across but am unable to locate specifically Bluetooth API.
No there has not be a release of source code or documents pertaining to bluetooth. Official product launch isn't until end of June.ad@sysenco.net wrote:Hello.
no - there are many infos about this - but only with NDA -WiFive - have you know about this possible way that we can get more infos and SDK and Tools with NDA? i am not.WiFive wrote:No there has not be a release of source code or documents pertaining to bluetooth. Official product launch isn't until end of June.ad@sysenco.net wrote:Hello.
Re: [Documentation Release] ESP32_RTOS_SDK_API Reference 3.0.0
hi guys
on pending ESP32_RTOS_SDK v3.0.0-16-07-23 release branch
there are new API Document v 3.0.0 too
read in
be sure you allways load from original place the right version to the right SDK release.
you see this in the "tree" of the version number
rudi
read in
rudi
I'm not sure these documents are for the released ESP32 ...
As far as I can see, these links point to a Github project located here:
https://github.com/espressif/ESP31_RTOS_SDK
If we visit that page and then look at the description at the top of the page, we read:
It is almost as though these docs were for the the early prototype boards (ESP31) and we are now being pointed to the "final" ESP32 where the ESP32 SDK is now called "ESP-IDF". If that's the case, the documents in these links (pointing to ESP31_RTOS_SDK) may not longer be truly relevant.ESP31B SDK on FreeRTOS. For ESP32 please see http://github.com/espressif/esp-idf
Re: [Documentation Release] ESP31_RTOS_SDK_API Reference
Hi Kolban,
Thanks, this is correct. I've renamed the thread to reflect this.
For ESP32, the API header files in esp-idf contain doxygen-style comment documentation. We're curently discussing how to host these in a formatted version.
Angus
Angus
Users browsing this forum: No registered users and 102 guests
