ESP32-Lyrat SPI connections
cmeineck
Postby cmeineck » Fri Dec 14, 2018 3:15 pm
Hello
I am looking for guidance, i am trying out the ESP32-Lyrat development board, i want to connect a RFID reader using SPI bus. Looking at the board there does not seem to be any direct way of doing this. I was wondering if i could use the JTAG connector and/or any other connections , i realise i would not be able to use the JTAG for debugging etc .
Any help would be good.
Chris
Re: ESP32-Lyrat SPI connections
Postby ESP_Sprite » Sat Dec 15, 2018 3:47 am
Yes, you should be able to abuse the JTAG port for that. I recall I did that for an earlier Lyra board and it worked well.
Return to “ESP32 ADF”
